MS3 3.0 Boost Control Trouble
Hey there,
I'm trying to set up an EBC using DIYAUTOTUNE's boost control mod kit and the solenoid. I've check that the solenoid works.
I guess I'm not too sure why it isn't working. Attached are pictures of my sloppy board and the tuner studio settings
https://ibb.co/LPPSbs0
https://ibb.co/1zkbBBC
Re: MS3 3.0 Boost Control Trouble
Did you fill numbers in to the boost duty table?
Turbo Slant Six in a highly modified S10 chassis
MS3ProEvo
The Car https://www.s10forum.com/threads/ss-10.855639/
The Motor https://www.slantsix.org/forum/viewtopi ... 12&t=56352
MS3ProEvo
I had not, I was trying to test it using the output testmode I/O, would the duty table have an effect of that?
As I understand it, you have to specify duty cycle numbers in the table to do any testing. In the process of testing you would change the duty cycle numbers to adjust how much boost control is commanded.
Zero equals no boost control, boost is limited by the wastegate spring. 100 is full boost, no pressure signal sent to the wastegate. Enough testing will allow you to build a table to limit boost however you want it.
I don't think this would affect I/O test mode but I haven't used that myself. My initial test was to set the duty table to 90 across the board. That makes the solenoid run all the time and I can easily hear it buzzing since it's attached to the firewall.
MS3ProEvo
MS3ProEvo
I havent tested it in the car, only on the workbench. I'll try 90% that and see what happens.
The boost tables don’t need to be changed. In the test mode you can click them on and off, or select pulse at the specific dc you type in on the test page
That's kinda what i thought but the post above made me second guess myselfnathaninwa wrote: ↑Sun Jun 26, 2022 2:38 pm The boost tables don’t need to be changed. In the test mode you can click them on and off, or select pulse at the specific dc you type in on the test page
I was trying that in test mode and was getting nothing, I'm guessing settings are wrong or it's wired incorrectly
Wire the ground trigger to an led or a relay coil and make it operate on/off to test the output.843244 wrote: ↑Mon Jun 27, 2022 8:01 amThat's kinda what i thought but the post above made me second guess myselfnathaninwa wrote: ↑Sun Jun 26, 2022 2:38 pm The boost tables don’t need to be changed. In the test mode you can click them on and off, or select pulse at the specific dc you type in on the test page
Sooooooooooo, I had swapped resistors. That was my problem.
You can test without duty cycle values, I was able to check in output test mode I/O-3
Thanks for the help
Thanks for the help
