Tighter 2 step rpm
Tighter 2 step rpm
Anyway we can change the firmware or tunerstudio to allow a "0" value for the soft limit rpm zone for the 2 step? This should net a tighter rpm swing on the 2 step
Re: Tighter 2 step rpm
I’m following. Curious to see where this goes as I’ve been trying to tighten mine up.
Edit the ini and you can set it pretty low. I wouldn't try 0.
The man behind MS Labs
Other ecus allow "high only" rev limiter. We can't do the same?
Has anyone following found anything out on this? I’d love to tighten mine up some.
Waiting on developers to see it....
I was waiting for you to test and see what happens.
I was expecting that reducing the zone excessively will give less tight control as the power will be more on-off and you'll have the "voom-voom-voom" behaviour of a factory car on the rev limiter.
