Volkswagen Scirocco 2 with MS3
Hello,
here is my build:
Volkswagen Scirocco MK2 with origine 1.8 16V engine 129HP. In the past i lightly modified head an manifold and put an other camshaft in the intake. With origine Jetronic it has 141HP / 162Nm at the dyno (all engine, not WHP)
My mods:
MS3 V3.0
315ccm Bosch injectors @ 3Bar fuel pressure
Audi/Polo triggerwheel behind the flywheel
Audi B4 throttle body (with poti)
Audi IAT
Golf TSI /Audi R8 COP
At the moment it runs semi seq and pretty solid. The ignition table is untouched, same as origine ECU has:
Engine: Case for MS3 build of aluminium and 3d printer parts: @the same dyno: No more HP added. But the torque starts around 800 to 1000rpm earlier, that is very noticeable.
I guess there will be more HP by change the ignition table. Check the Volkswagen repair manual: I can add 3 degree more and still in the manufactor tolernace of the ignition, so there should be more power.
At chrismas i will get my MS3x board, then i will change the ECU to full sequentiell, modify ignition and a little change at the head intake. After that to the dyno.
here is my build:
My mods:
MS3 V3.0
Audi IAT
- Attachments
- CurrentTune.msq
- (272.83 KiB) Downloaded 162 times
VW Scirocco MK2 , MS3 V.3.57 with MS3x . Fully Seq.
Re: Volkswagen Scirocco 2 with MS3
I love it. Looks great.
Looks like there is room for a turbo.....
Thank you!
New season. New wheels, new pads. Ready for some track use.
MS3x Board works fine, engine runs fully sequential. The lasts weeks i am testing and configuring injector timing, do some Auto VE tune. Mostl engine states works fine, even idle with ego control is possible and stable.
Only firing up when coolant is between 10 and 20degree C isnt good, took 3-4seconds cranking. Below and Above its fine. But this would be fixed next time.
Great job! I'm curious what you going to do next
Thanks.
Had two trackdays in the past. The car performs good, even which less power than the others. Low weight is good for corners.
Engine works fine, still do some fine tune and the megasquirt gets better and better.
- Attachments
- Scirocco MK2 full seq 20230726.msq
- (285.46 KiB) Downloaded 126 times
So,
Moved the throttle position stop to access lower idle rpm. Did changes in idleadvance and sensor smoothing. Its amazing who much potenital is still there to tune and get the engine better, smother, faster, more stable.
Gas consumption drops from 8litres/100km (origine Bosch jetronic) to 6,5Litres/100km @long Autobahn drives , what a saver.
Next update will be second baro sensor. Bought Infineon baro chip, only need 5V, ground and has a 0-5V Output. Still to do, print a little case and do wiring. Its hobby.
- Attachments
- Scirocco Mk2 16V 202309.msq
- (285.46 KiB) Downloaded 98 times
- PXL_20230916_173126380.jpg (385.58 KiB) Viewed 2747 times
