For some reason, I can't post on Jean's site, so I'm posting here hoping Jean will see it.
I had to unsolder some wire on my TinyIOx and I was overly aggressive on pulling out the ground wire and I tore the solder rings off the board.
As near as I can tell, it doesn't look as if it matters on the front of the board (although I would like confirmation). It looks as if grounding takes place on the back of the board.
Can I scape the area clean (that I have identified in my pic) that is next to the ground hole and solder there?
TinyIOx alternate ground location
You do not have the required permissions to view the files attached to this post.
6.2L LS3, Procharged, MS3X V3.0
22' Donzi Classic
Not yet running...
http://www.donzi.net/forums/showthread. ... 502-to-LS3 (Disclaimer: Contains naive info )
22' Donzi Classic
Not yet running...
Re: TinyIOx alternate ground location
Don't scrape the solder mask. The solder pad just besides the missing one is also a ground (part of the BDM 6-pin header). Other easily accessible ground locations are the 2.5mm jack pad closest to the board edge, the 'BOOT' header pad closest to the board edge and the 3-pin header pad furthest from the board edge (only visible on the bottom of the board; the RS232 chip covers the top).
Let me know if that's not clear.
Thanks Jean! Appreciate the response.
22' Donzi Classic
Not yet running...
22' Donzi Classic
Not yet running...
22' Donzi Classic
Not yet running...
22' Donzi Classic
Not yet running...
