I've searched the forum but could not find information about my question.
I'm designing a PNP ECU based on a Microsquirt module. My goal is to be able to use the EDIS-6 (and camshaft sensor) that's currently in the car but I would like to be able to run semi-sequential injection (3 pairs of injectors).
I know the extra drivers I have to build but I'm not sure if the software can handle the semi-sequential injection without the trigger wheel directly connected to the ECU.
Any help is appreciated.
Thank you.
Semi-sequential injection with EDIS-6 and CMP
Re: Semi-sequential injection with EDIS-6 and CMP
I'm pretty sure the code doesn't support that. Hopefully you've moved forward with the project since you posted this. If not, my suggestion is to dump the EDIS module, and run the VR sensor straight to the uSM.
