Input RPM signal
Input RPM signal
I'm trying to get an input rpm signal tapping into the stock VDO tach on my Mercedes 300SD. I hear its 0-5v signal not 12v. I'm getting very erratic tach readings. is there a way to configure it to 5v or do I need a booster to get my signal to 12V?
1983 Mercedes 300SD OM617 Holset HE200wg, 7.5mm Injection pump. working on a 4L60e swap to gain overdrive and a lockup converter.
Re: Input RPM signal
Id put a scope on the tach signal and see what you have.
It also depends on what hardware you have.
I need a wheelbarrow full of clues to even guess.
The MS will take a 5v signal, I d guess the trigger level is 2.5v (MS2 per setting of R56)
