DBWx2 throttle controller
LS4 throttle body (8 wire)
2006 monte carlo APP
as I drive my car, I can see the WOT engine state set regularly at well below the threshold set in the engine states window, in the screenshot below you can see 15% throttle triggering WOT.
I'm not currently using the WOT state as a trigger for anything, but I'm also not the only one who has seen this
TexasJeepLJ wrote: ↑Fri Aug 25, 2023 8:00 am Got an issue...
Can get the controller to go into Closed Loop idle. What am I missing......
Of note; on the VSS page; as soon as i touch the throttle, it shows WOT as soon as I tap the throttle. Not sure if that has anything to do with why I can't get it to enter Closed Loop.
Attached are the MSQ's for the BDWX2 and Megasquirt.
Any help would be great.
Thanks,
Rich
I'm guessing this has something to do with idle control Max idle addition(%), but I'm really not sure, anyone have any insight?
other, less pertinent details
1985 Fiero
05 malibu 3500 V6 engine
cam, 6266 turbo, ported intakes, heads
5 speed manual
