VR work, have a look how toyota have done it since the 90's..... (ie on the 1FZ-FE)turbothis wrote: ↑Mon Nov 06, 2023 9:43 am the main goal is just to have fun and get it done
not ultimate or even elevated performance
i like to build weird headscatching things. they are not for everyone
dizzy only install.....
the v8 needs a wheel evenly divisible? meaning i would need to use like a 32 tooth not a 30 tooth?
if i had no missing teeth and then a half moon on top? for the start of phase
i can use hall to if that is better
the porkshop would be moving pretty slow for a VR right?
V8 tooth wheel IN dizzy
Re: V8 tooth wheel IN dizzy
cool, ill read into it
thanks
thanks
2002 Montero dakar rig
FORD 3.0L DOHC duratec / 6HP26
gt3582 boost to the moon
Ms3X running and making fire!
dodge M37 look-a-like 1 ton
4.2l chevy atlas / 6R80
66mm turbocharger ~8#
Ms3X sequential finally kicking some butt
Late to the party, but I wanted to point out that you cannot use a VR sensor with a half moon. You must use a Hall sensor.
makes sense
