Once there is a more advance water/methanol (WMI) setup other than the standard post intercooler 1 or 2 nozzle plumbing, then the simple low water mix tank level trigger isn't quite sufficient. Multi nozzle Direct Port setups, Volute spray, or Pre-compressor spray setups require more dynamic controls and proper safeguards.
System safeguards can be established from a system pressure sensor, IAT/MAT, EGT, etc. Some active system response can include:
- When the system is activated, if the pressure sensor feedback indicate a low / minimum designated pressure after a predetermined elapsed time, then this will generally indicate issues with the pump, or a pinch feed line.
- When activated, if the pressure sensor feedback indicates (extremely) low pressure, then this will generally indicate that a feed line is open or leaking (dumping out on the ground pressure).
- High/Low variance within a certain time period (spikes). If presor sensor feedback spikes within certain amount of time, then this will generally indicate clog nozzles, or blockages in downstream lines.
- IAT/MAT feedback - If a certain designated minimum anticipated air temp isn't achieved while the system is engaged, then the system nozzles aren't spraying as expected, clog nozzles, of some other component is malfunctioning.
Picture for reference
