Conditions for activating Generic PWM
Hi all. I was faced with the task of organizing PWM activation only on the condition that I understand that this can be done using an additional relay and an On/Off output, but these are additional elements. Question for the developers: is it possible to programmatically add PWM activation conditions similar to programmable On/Off outputs?
Re: Conditions for activating Generic PWM
I'm not a developer but you can use generic PWM for on/off functions. You set it in the frequency selection.
Support the developers!
The Generic PWMs don't have an enabling condition, although this has been a feature request.
You might be able to use the boost control function as an 'enableable' PWM, or something like that, depending on your exact needs.
Bob
Bob
Yes, excellent if the developers can add a PWM activation function under the conditions. Where can I send a proposal to improve MS3?
