Hello,
Air Cor does not contribute to Total Cor during ASE taper phase. If Air cor is e.g. 110%, at ASE taper end Total Cor jumps by these 10% hence there is a short phase before ASE taper ends, where these 10% are missing and enleanment takes place.
Would see Air Cor contribution during ASE taper pahse as an enhancement.
Best Regards, Franz
See attached Log at 19sec.
[feature request] Air Cor should be acounted for from motor start on
- Attachments
- 2023-12-08_14.54.35.msl
- (249.5 KiB) Downloaded 45 times
Re: [feature request] Air Cor should be acounted for from motor start on
I'm very well aware of "changing things, causes troubles". A linear transition from 100% to AirCor-Value during the ASE taper duration would be migrition wise possibly a quite safe approach (means minor or no changes needed).
On my set up, I have "Ignore MAT Correction During ASE" to help with hot starts.
You do not want this setting if your are dealing with very cold starts. Check your Cranking/Startup Settings.
Oooh, I missed that! This is enabled. Thanks a lot!
Sorry for everybodys time loss (started 3 month ago with freely programmable ECU's and obviously missed this)
Maybe this thread should be deleted?
