Timing retard over Canbus
I'm working on integrating the turbolamik transmission controller for an 8hp and I think it would be a great feature if we could have a settings for doing timing retard with generic canbus receiving.
The trans controller can do it with the ms3 but it uses the Megasquirt 29 bits protocol that nobody else uses.
The other temporary solution is spark table switching but I'll need the table so it would be great to have a feature directly linked to that.
Re: Timing retard over Canbus
This should work via CAN Receiving - however you'll need to grab the very latest pre-1.6 RC1 as I found a typo in the ini file that was stopping this from working.
"SpkAdj" is the field you want.
I just loaded the rc1 and found it. I'll try and report how it goes.
Thanks!
Thanks!
I tried it and I was able to make it work!
Value is in 0.1 degree of advance. So to remove 20 degress for spark retard we need to receive -200.
Glad it worked out.
Hey, I'm trying to control my Aisn Aw4 (essentially A341e) with arduino. I want to do the retard timing with the exact method you've used and this is the only place I can see somebody attempt it and not using megashift. Can you share your setup please?
I'm trying to figure it out what message should I sent to make it happen and what is the setup in tunerstudio.
dlenk: Just go in the CAN Receiving menu, get your id and offset and select SpkAdj in the dropdown.
One other request for James!
Is it possible to do a spark cut from canbus?
I tried the spkadj but finally it doesnt remove enough power to shift the transmission so I really need to do a spark cut.
I had the idea to map the value to a generic sensor instead, and then use a loop to be active as soon as the value received from the canbus was bigger than 1 but it's too slow.
So I had to use a real digital output from the Turbolamik and link it to the Sequential shift feature instead.
But it would be great if we could do it over canbus.
Here is a screenshot showing (sensor 07 data which is a value received from the can adc 07, loop condition 8 turning ON immediatly but spark cut happening wayyyy later But with physical digital input, it works perfectly.
Did you give permission to the external controller to remove more then 15° as the is a default limit for max time retard
