Currently working on a 16v 4AGE large-port in a Corolla w/ a pair of side draught carburetors but using the factory VAST igniter and distributor.
Microsquirt Wiring
4 tooth vr sensor from distributor: NE+ > VR1+, NE- > VR1-
1 tooth vr sensor from distributor: G+ > VR2+, G- > VR2-
IGN1 output to IGT pin on VAST igniter
I initially had Ignition Input Capture set to Rising Edge but wasn't getting any rpm signal. When I changed it to Falling Edge then I started getting an rpm signal. It goes "bleh bleh bleh bleh" and acts like it wants to catch but nada.
I've scoured the MS2/Extra, MS2, Microsquirt... section for other similar setups to confirm my wiring and settings but mostly found megasquirt projects.
Could someone point out what I'm missing and/or doing wrong?
.msq file attached.
Microsquirt v3 - 16v 4AGE Factory VAST ignition only *SOLVED (w/ help from outside source)*
Last edited by thejuanandjonly on Fri Mar 08, 2024 10:22 pm, edited 1 time in total.
Re: Microsquirt v3 - 16v 4AGE Factory VAST ignition only
Please disregard this thread now. I've successfully resolved my issue w/ help from an outside source.
