Hi all,
I hope someone here will be able to direct me in the right direction, I am clueless as why I have the follow issue.
I have a Microsquirt-Module hooked up to my Linux machine running TunerStudio, but I can't get the High Speed Logger to display anything.
All other communications are working, I can manually control the fuel pump from the "Output Test Mode - I/O" menu, and the gauges are working just fine for all my analog channels.
Hardware: FTDI cable, Microsquirt-Module V2.2M
Firmware: MS2/Extra 3.4.4 release 20201006 18:17BST(c)KC/JSM/JB uSM
PC: Linux Ubuntu 22, running TunerStudio MS Ultra v3.1.08
also tried on Windows 11, running TunerStudio v3.2, same result
I haven't modified my MSQ file yet, I am still using the default one coming with the firmware release.
I tried a couple other firmware versions with the same result.
Any help will be appreciated, I can't wait to get my 1977 VW Bus back on the road.
Happy tuning!
Do Data Received from Controller (High Speed Logger)
- Attachments
- default-3.4.4-microsquirt-module.msq
- (116.01 KiB) Downloaded 5 times
Re: Do Data Received from Controller (High Speed Logger)
What RPM/tach source are you sending to the module?
