Hi all, first time posting on here and my first microsquirt project so I'm learning as I go so help me out if you can!
I have a microsquirt module and a Volvo b21ft engine (mostly though it seems to be a Smörgåsbord of parts. The setup related to the microsquirt is as follows:
We have gotten the car to start but cannot get it to idle for more than a dozen seconds and not without rediculous backfires and misfiring. We think everything is mechanically sound (More or less). I've attached our tune and a data log.
Main questions are:
If our VE table is remotely close to what it should be, we have used the built-in tool and tried to research and tried messing around with it but not much progress, and it's been a long time.
If our timing is horribly off, hard to find any forms on b21 engines but it seems to run best at idle when it's retarded a bit, we have it around 5 dg for cranking however which seems to be best.
Pretty much lost at this point if anyone has somewhere to start hardware or software
your rpm signal is losing sync. is it a factory fit crank wheel / sensor setup? can you take a tooth log
grom_e30 wrote: ↑Fri Mar 22, 2024 6:15 am
Hey thanks for the reply, It is not a factory setup, attached are photos of the setup and the tooth log.
Hopefully, you can see these photos. It seems a little futsy to get photos in the forum. one log of with fuel other log of longer cranking w/o fuel so its more steady
i would be looking at simple things first as its a retrofit like sensor air gap. trigger wheel runout, make sure the mounting for the sensor is really sturdy so it can vibrate and change the sensor gap ect.
grom_e30 wrote: ↑Fri Mar 22, 2024 11:57 am
Ended up changing the hall sensor setup and reducing vibration/ crank pulley wobble and started up. Thanks!
