Hello
is it possible to have a sort of way to trimm boost duty in open loop using vss2 (undriven)?
i would like to give my ca18det the extra duty at low speeds while on 1st/2nd gears.
Boost vs speed trimming available?
Re: Boost vs speed trimming available?
When i enable VSS2 on the "Boost vs speed/Gear" drop down menu this enables the Boost vs Speed table that in openloop mode is duty% vs speed.
Now is this table the one in command of duty% and ignores the main Bosst control duty table?
Or is it some type of trim?
- Attachments
- boostvsspeed.png (180.6 KiB) Viewed 60 times
