YES! with the help of a lot of people I talked to and some of there here on the forumI got my LPG injection system up and running.I changed the name of the topic to "...my tuning story" and will be sharing my tuning story as I move forward on my project in this topic. Hopefully it will help others and it will give me a place to upload and store info for future use.
Some info on my setup:
GMC C15 Suburban, see projectpage in my signature
engine: 454 Chevy Big Block low compression about 8:1
single fuel: only LPG injection
ECU: Megasquirt MS3X (see tune in attachments)
Reducer: Tomasetto AT13XP set at 150 kPa gas pressure (rail pressure - MAP)
(replaced this reducer: Femitec FR400)
Injectors: Valtek 30 BFC, 3 Ohm
(replaced these injectors: Femitec GIAC-01 (2 Ohm)
Peak&Hold boards (4A/1A) from SECU-3.org
I have extra sensors for LPG connected in one itegrated unit:
- gas pressure (mpxh6400a)
- gas temperature (10 kOhm NTC)
- external MAP sensor (mpxh6400a)
Ignition is:
FAST dual sync distributor for crank and cam signal
8x LS D585 coils at 3.5ms dwell
Transmission: 4L80E
TCU: Microsquirt connected by CAN to the MS3X
I even went for a testdrive tonight. Got my Suburban up to over 70 kph even and felt really good driving it!
I blocked the idle fields in the Autotune, cause somebody told me Autotune can be a little rough in these fields, and then went on a drive.
I drove great. First a little through the neighbourhood at low speeds and then took the open road. Hit the throttle and got it up to about 70kph. Pulled into a parkinglot to see check out my laptop and the and what autotune was doing. At first it idled fine and then suddenly for no reaso I can think of so far it started surging.
I didnt want to get stuck in the parkinglot so put it in drive and limped home. It ended with a big LEAN bang in front of the door. I dont think the log file gor the LEanb bang though. But the surginng is clearly in there in the 2nd part of the log file
Could you guys give my MSQ and log file a look and see if you can give my any pointers as to what might cause this surging?
I have added the MSQ file to this topic, but the LOG file was over 1MB so I have shared it from my Google drive. Hope that works:
https://drive.google.com/file/d/17bGoUF ... sp=sharing
thanks...Im so excited.
here is a video of my first cold startup I made: https://youtu.be/xuskv7_qB6Q
and this is my Autotune settings:
