On an ITB engine, there isn't much volume behind the throttle bodies, and that volume can fill very quickly. I don't however think it's going to fill enough between ignition events to cause us to be very far behind. You're certainly not going to go from cruise kPas (say 40ish) to 100 kPa in 1 step between ignition events.Peter Florance wrote:Ken,muythaibxr wrote: Once we schedule a spark event, if the tooth it's scheduled from changes, we don't update that event... it happens then we schedule the next one, so if you could go from high timing (35-40 degrees) to a lower timing (20ish) in the time between spark events (very small, especially at revs higher than idle), you might be able to cause a problem. However, there's no real way to solve this one.
Do you think the manifold can fill that quickly?
so far seems like non-issue to me.
I think worst case you might be 1 or 2 ignition events behind before everything catches up, which means your timing will barely be off from where you want it... it's not going to be a difference of actual timing of 40 degrees when you wanted 20, it'll be more like actual timing is 20.3 when you wanted 20. That's my initial take on it without doing the math anyway.
