HEI 4 pin to run COP's? 6 of them......
ok, i want to know if i can run my v6 with dum COP's (2 wire ford)
and have 6 of these instead of the little BIP373 bastrads. or maybe 3 in wasted spark
wiring the right side of R25 R26 R28 to the negative of the HEI 4 pin
and maybe running 12V to the positive input. this way ground switched?
something like this but 6 cylinder
2002 Montero dakar rig
FORD 3.0L DOHC duratec / 6HP26
gt3582 boost to the moon
Ms3X running and making fire!
dodge M37 look-a-like 1 ton
4.2l chevy atlas / 6R80
66mm turbocharger ~8#
Ms3X sequential finally kicking some butt
Re: HEI 4 pin to run COP's? 6 of them......
I wouldn't advise using the HEI4 modules. That information in the manual dates back to say 2004 when MS1/Extra couldn't even control dwell. The HEI4 isn't designed to be operated this way and was "better than nothing." The BIP373 is actually designed to do the job.
interesting, but it does work this way?
I would use a module that had multiple ignition drivers, such as what some imports, such as Nissan have. Similar wiring compact and designed for this type of application.
Tha Daily: 2005 Chevy Blazer
they look to be expensive and likely not at every auto parts store
got a specific model or link?
found some amazing reading on coil stuff!
http://dtec.net.au/Ignition%20Coil%20Dw ... ration.htm
https://opensiuc.lib.siu.edu/cgi/viewco ... =auto_pres
so i got my arduino pulsing out 15Ms with 1Ms dwell
i ran it slower with the HEI module and both the coil and module get very hot!
with the bip373 both runs cold the whole time
