Does the TFI module do any conditioning on the pip signal sent from it or can I connect directly to the hall sensor on the distributor and run it in to pin 24?
Reason I'm asking is I have a swap engine from a 94 mustand which has an external TFI, which didn't come with it. Just wondering if it's necessary to wire one in or not?
I've got a MS2 with v3.0 board I'm piecing together and have a Crane CD ignition and coil I'd like to run instead of running the coil off he TFI module.
Here's a DIY diagram of the connector on my dizzy but their set up is running coil off the module.
Thanks!!
TFI module necessary with MSD or CD ignition?
'89 Volvo 245 wagon w/ford 302 w/T70@10psi
507whp/468tq
'66 Mustang hardtop turbo project in the future!
507whp/468tq
