Passing on the transmission temperature to the ECU
'Microsquirt' Transmission Control development and support.
Post by Matt Cramer »
I've got a customer who is trying to use the transmission temperature to make his MS3 switch on a cooling fan. I've figured out that it looks like the basic steps should work like this.
1. Go to CAN Parameters, enable ADC poling, and configure the CAN ADC group 1-4.
2. Map a generic sensor input to CAN ADC2 and set it for GM temperature calibration.
3. Configure a programmable on/off output to trigger off that generic sensor input.
Where I'm stuck, though, is the exact settings for the CAN ADC group. The CAN ID would need to be 7, but I'm stumped on what table and offset to use.
jsiedlicki
Re: Passing on the transmission temperature to the ECU
Post by jsiedlicki »
I don't know what add on board you are using but I have a tinyIOX with 9 CAN ADC's and it uses Table 7, Offset 2 for ADC 1-4. Should be the same for your board.
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
racingmini_mtl
Post by racingmini_mtl »
Look at the ini file in the output channels section. The command gives you the table number and the offset is listed for each variable. So for the latest beta, that should be table 7 and offset 16 (adc0).
jsiedlicki
racingmini_mtl wrote:Look at the ini file in the output channels section. The command gives you the table number
I see where in the [OutputChannels] section the offset is found but where do you look for the table number?
racingmini_mtl
The second parameter of the read command is the table value (x07):
Code: Select all
    ochGetCommand    = "r\$tsCanId\x07%2o%2c"
jsiedlicki wrote:I don't know what add on board you are using but I have a tinyIOX with 9 CAN ADC's and it uses Table 7, Offset 2 for ADC 1-4. Should be the same for your board.
This was for use with the MicroSquirt transmission control.
With that firmware, do the output channels in the INI correspond to anything to do with CAN?
jsiedlicki
racingmini_mtl wrote:Look at the ini file in the output channels section. The command gives you the table number and the offset is listed for each variable. So for the latest beta, that should be table 7 and offset 16 (adc0).
I believe Jean has you covered with his reply, table 7, offset 16. Let us know if it works!
EnergeticMotorsports
Post by EnergeticMotorsports »
Did you get this to work?
kikkegek
Post by kikkegek »
just to complete this topic and since it helped me a lot Im sharing my CAN settings.
I have a MS3X connected to a Microsquirt Transmission Controller for a 4L80E
and I have succesfully brought forward the trans temp this way.
these are my CAN parameters
CAN parameters 4L80e Microsquirt Transmission Controller.jpg (116.32 KiB) Viewed 820 times
my project page, BBC 454 with LPG vapour injection:
my BBC 454 LPG vapour injection tuning story 8)
my Facebook projectpage:
My 1977 GMC C15 Suburban "Storm" 8)
