...Please define in MSGraph.properties
I get this message when I click on Run Analysis for veBins1. About an hour ago I thought I knew what it meant, but I guess I really don't
Msns-e v3
029t
MegaTune 2.25
MegaLogViewer 2.52
DEFINE_CURRENT_CELL_VALUE not found in Properties File...
You should never need to define these values, The only way that message should come up is if
1) MLV can not find MSGraph.properties
2) An old version of MSGraph.properties without that entry (Pre 2.2)
3) File has been edited and entry is corrupt or missing.
A quick check for number 1 is to look at the "Calculated fields" menu, There will be no WB O2 sensors listed.
What OS are you running on?
Sorry it took so long for me to get back.
This is on XP sp2 all updates. I will uninstall and reinstall fresh.LT401Vette wrote:You should never need to define these values, The only way that message should come up is if
I actually had 2 entries listed in my add/remove programs.
After uninstalling both of the MegaLogViewer and reinstalling from the .msi on the site, it is working. Maybe something in the upgrade didn't work right *shrug*
Thank you for your help
