Dictionary for MegaLogViewer Calculated Fields
Postby LT401Vette » Tue May 22, 2007 8:34 am
This is a list of all the optional calculated fields in MLV and their meaning. I will keep adding to it and include it on the MLV site.
Wideband O2 AFR - Air Fuel Ratio calculated based on O2 field for specified WB sensor. This is for MS1 only, MS2 typically logs AFR directly to an afr field.
Wideband O2 Lambda - Lambda calculated based on O2 field for specified WB sensor. This is for MS1 only, MS2 typically logs Lambda directly.
Boost(psi) - Converts MAP to psi with 0 = to atmospheric pressure.
- Input: "Engine off MAP pressure in KPA" - The MAP value while the engine is not running, corrects for sea level and error.
VAC(inHg) - Converts MAP to vacuum in inHg
Boost-Vac - Below atmospheric pressure Vacuum in inHg, above Boost in PSI
TP ADC - Calculates the original ADC value based on TP in percentage.
- Inputs:
- "Maximum TPS ADC" - the ADC value with your throttle at wide open.
- "Minimum TPS ADC" - the ADC value with your throttle in idle position
MPH\ Xxx\ Gear
- Inputs:
- "Tire Diameter(in.)" - Drive tire outside diameter in inches
- "Final Drive Ratio" - Axle drive ratio
- "Transmission gear ratio" - ratio for the transmission gear used
KPH\ Xxx\ Gear
- Inputs:
- "Tire Diameter(cm.)" - Drive tire outside diameter in centimeters
HP - Horsepower calculated from rate of speed change. Car must be in the defined gear on level ground for accurate results. Currently uses US measurement units only.
- Inputs:
- "Min TP to calculate for" - Filter condition, HP will only be calculated when TP is over this value. This heavy calculation will slow log load times if hp is calculated for the entire file.
- "Converter stall speed (0 for manual trans)" - Converter flash stall, the RPM that you flash to from a stop with traction.
New or changed for 2.68:
Fuel Flow - Total Fuel flow for combined injectors in lb/hr or cc/min depending on what rating is used for the injector input.
- Inputs:
- "Injector Opening Time" - the injector open time configured in you MS, usually 1.0
- "Alternating(enter 0.5) or Simultaneous (enter 1)" - whether your injectors are configured to fire Simultaneously or alternating.
- "Number of Squirts" - Number of squirts per cycle configured in your MS
- "Injector Size" - the rated or corrected rating for your injector
- "Number of Cylinders/Injectors" - Number of injectors.
Instant MPG - point in time fuel economy in Miles per gallon. Like the instant MPG gauge in many modern cars.
- Inputs:
- "Transmission gear ratio" - ratio for the transmission gear used, for Instant MPG usually your high gear. 1.0 in non overdrive transmission, less if overdrive equipped.
LT401Vette
Postby LT401Vette » Tue Jul 10, 2007 1:32 pm
Some of the standard core MegaSquirt field definitions:
---------Eric Fahlgren's description of headers in the datalog file---------
Time - Real time clock in 0.001 resolution.
SecL - Low byte of MS internal clock, rolls at 255 back to zero.
RPM - Revolutions Per Minute, RPM/100 on some MS1 embedded codes.
MAP - Manifold Absolute Pressure in kPa.
TP - Throttle Position in percent.
O2 - EGO sensor voltage.
MAT - Manifold Air Temperature in user-selected scale (either F or C).
CLT - CooLant Temperature, also in user selected scale.
Engine - Engine bits.
Gego - Gamma EGO in percent.
Gair - Gamma Air temperature in percent.
Gwarm - Warmup Enrichment Gamma in percent.
Gbaro - Barometric Correction Gamma in percent.
Gammae - Enrichment Gamma, product of all of the above gammas, in percent.
TPSacc - TP acceleration enrichment pulse in ms.
Gve - Gamma VE (table lookup value), for bank 1, in percent.
PW - Final pulsewidth, for bank 1, in ms.
Gve2 - Gamma VE (table lookup value), for bank 2, in percent.
PW2 - Final pulsewidth, for bank 2, in ms.
LT401Vette
Re: Dictionary for MegaLogViewer Calculated Fields
Postby Ralco_Be » Wed Oct 29, 2008 3:45 pm
LT401Vette wrote:.........
- Inputs:
- "Tire Diameter(in.)" - Drive tire outside diameter in centimeters
Isn't this an error? When I put the values in centimeters, my ca has 260 Hp ?
With the tire Diameter in inches, the calculation is better...
Opel Ascona B i2000 MsExtra Alpha-N
Kadett C Coupé C20XE Motronic
Ralco_Be
Postby LT401Vette » Wed Oct 29, 2008 5:33 pm
oops, yes it should say inches. i.e the (in.)
cm would really mess up the output.
LT401Vette
Re:
Postby Mario » Sat Aug 21, 2010 11:40 am
LT401Vette wrote:Some of the standard core MegaSquirt field definitions:
Is there and updated list of definitions availale?
1967 Beetle My test mule
The Dub Shop
Facebook
Megasquirt for life!
Mario
Postby Trump » Sun Jul 17, 2011 9:30 pm
Could some one advist what the Status 1,2,3,4, and 5 are and where I can find this info?
Sydney Australia
Triumph TR3A. MS3X, Fully Sequential Injection, Wasted spark, 60-2 crank wheel.
Trump
Postby LT401Vette » Mon Jul 18, 2011 6:13 am
Those fields are specific to the firmware, however are relatively consistent across the extra and ms3 firmware, but what ones are available will depend on your firmware.
Any way, they are bit flag fields where different bits will be turned on to indicate the on/off state of various items. They are often used to drive the indicators on the dashborad. That is the best place I know of to find out what bits mean what is to look at the indicators in the ini file.
i.e. snippet from an ms3 ini:
Code: Select all
   indicator = { status1 & 0b00000001}, "Need Burn",   "Need Burn",   white, black, red,   black
   indicator = { status1 & 0b00000010}, "Data Lost",   "Lost Data",   white, black, red,   black
   indicator = { status1 & 0b00000100}, "Config Error",   "Config Error",   white, black, red,   black
   indicator = { status1 & 0b00001000}, "Not synced", "Synced", red, black, green, black
   indicator = { status1 & 0b00100000}, "VE1/2", "VE3/4", white, black, green, black
   indicator = { status1 & 0b01000000}, "SPK1/2", "SPK3/4", white, black, green, black
Now by looking at that you can see that in status1, if the 1st bit is set, "Needs Burn" is being reported. If the 3rd bit is set, there is a "Config Error"
So while in MLV just looking at a status field is not very useful. If you have a specific condition you are looking for, you can create a new field based on these.
For Example if you want to see in MLV if you were running on the switched tables "VE3/4", you can create a new custom field:
Field Name:TableSwitched
Formula: ([status1] | 32) == 32 ? 1 : 0
You will now have a new field after a reload called TableSwitched where it will have a value of 1 when you are on the switched tables and a value of 0 if not.
LT401Vette
Postby maximus » Thu Feb 26, 2015 11:46 pm
Hi, didnt find how to append a new dictionary ? I created one for my needs and put in FieldMaps directory, but seems MLV need some setting to see it.
maximus
Postby LT401Vette » Fri Feb 27, 2015 7:29 am
I'm not sure what the FieldMaps directory has to do with the Field Dictionary. It didn't even exist in 2007 when this thread was alive.
What the Field Maps are for is for MLV to map know file namings to a canonical naming. This way the formulas can be written to the canonical naming, then MLV can use the field map when evaluating the expression, thus the same formula will work with a current MS3 or an old MS1 even though they have different names for field representing the same thing.
LT401Vette
Postby maximus » Sat Feb 28, 2015 12:29 am
Thxs for reply.
As a newbie here, I wanted to post on similar thread rather than create a new topic..
My purpose is to create a dictionary to "speak" the same language as MLV with logs coming from ecuEdit(used to log subaru/evo with it).
So I can use same filters, formulas and short naming conventions inside MLV.
eg : Air\ Flow\ Sensor\ Voltage\ (V) is not very friendly to use with MLV ;)
maximus
Postby TrendSetter » Wed May 31, 2017 5:04 pm
is there any kind of documentation that specifies what all the expected fields are named for these calculated fields?
I am using mlvhd to view csv logs from an openlog2.0 on a evo and i can define the field names as needed. I want to start using the hp and acceleration calculations built in to the software but none seem to work right now with my current field names.
When i try to activate the fields they seem to fail silently so there is no feedback for me to troubleshoot.
TrendSetter
Postby whittlebeast » Wed May 31, 2017 5:34 pm
This is a Megasquirt specific site but if you PM me your email address, I may be able to help. I bet you could even guess my gmail address.
Andy
whittlebeast
Return to Megalogviewer
