y axis question
y axis question
I am using MAF for fuel load but using map/speed density for the time being for spark advance and the AFR target table. Is there any way to have VE1 pulled up in the tuning console and the spark or afr table up also and have the top table y axis as load and the bottom table y axis as map? Im thinking not but thought Id ask . It sure would make viewing the log versus the tuning tables easier to interpret.
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: y axis question
Yes, if you right click on the Y Axis you can set a Y Axis over-ride for any specific table from the over all Y Axis set in the main menu.
Re: y axis question
Wow cool Phil. Thanks so much.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
