1024 X 600
1024 X 600
My main laptop i use for ms stuff has a 1024x600 screen size and in mlv 'under calculated fields' in the 'optional fields' i cant see all the options because they are off the bottom of the screen, would there be a way of making that menu scroll or some other way to be able to see all the options.
Re: 1024 X 600
I have the same issue with my eeepc
I put my screen in 1024x768 mode. When I do that, I only see 1024x600 but when I move my cursor, the screen move so I can see other things but it's not very practical.
Re: 1024 X 600
iv only got 1024x600 or 800x600 neither helps
Re: 1024 X 600
Yes, the Calculated field menu needs to change. I have had a number of users that make a lot of Custom Fields have a similar problem.
