Can anybody please help, I have just changed over to using tuner studio from megatune and I now have a error -1 box showing when I try to view a log. This has only started since I changed over to tuner studio as all my previous logs are OK.
What is the error -1 referring to does anybody know?
Les.
error code -1
Re: error code -1
It sounds like a parsing error.
Can you post a data log that isn't loading?
Re: error code -1
Thanks for the help, file attached.
Les
Les
Re: error code -1
That file seems to open fine.
What version of MegaLogViewer are you using?
It may be that you are on a very old version. TunerStudio logs units and old versions of MegaLogViewer do not parse that.
Re: error code -1
Yes I am using a 2010 version of MLV I have just downloaded MLV lite 3.4.04 and that opens the log OK however the lite version limits the log size I find, that's why I prefer to use the older MLV . So now that I am using tunerstudio I need to ether use MLV lite to read my logs is that correct or use some other program ?
Les.
Les.
Re: error code -1
MLV lite would be the correct program to use.
If you used an old TunerStudio from that same era, then the old MLV will work. But new additions and improvements sometimes call for compatible current versions of other programs.
Re: error code -1
Many thanks for your help and advice.
Is it still possible to get an older version of tunerstudio ? and if so how ?
Les.
Les.
