Strange things happening
tutuur
Post by tutuur »
I recently started having a strange problem with MLV.
When i open mlv the menu option buttoms and the logging selection buttons text are almost not readable, when i glance over with the mouse they become readable but others change.
I'll make a video and upload to youtube later as the problem is a bit hard to explain.
Regards,
Arthur
tutuur
Re: Strange things happening
Post by tutuur »
So here's a little video of what it does, sorry for the strange format...
http://youtu.be/ZQpNY90UrA8
DaveEFI
Post by DaveEFI »
A virus etc of some sort?
tutuur
Post by tutuur »
Computer is fine, only does it with mlv
Post by LT401Vette »
That is quite peculiar...
What JRE does it say it is runing on in the About Dialog:
Main Menu --> Help --> About
tutuur
Post by tutuur »
Java runtime version: 1.8.0_05
i've just re-installed mlv and opened it directly after setup, worked fine after that.
then i read your message and opened it again to check your suggestion and the problem is back again....
i have the latest 32 ánd 64 bit java installed....
1.8 is a beta JRE, I wonder if that is related.
Perhaps try installing a 1.7 JRE
tutuur
Post by tutuur »
just installed the older version and it cured the problem.
thanks!
Arthur
