When I open up my datalog and open the msq to the data log if I open both ve tables, in the analyze view, then MLV brings up a default afr table... not the one from my tune if I close one of the ve tables and open the afr target table it brings up the one in the tune correctly.
any thoughts? do I need to make a copy of afr table 1 and call it afr table 3?
table switching analyze default afr table?
Re: table switching analyze default afr table?
When in VE Analyze with Advanced Settings visible, right next to the "Hide Advanced Settings" Button, there is a Button to select what target AFR table to use. Can you select your target table from there?
If I tried to open both ve tables to see what was happening in the log then the default afr table showed up, for ve analyzing, if I only have one ve table open at a time, then I can choose the correct afr table for the tune. just cant look at both ve tables 1 and 3 and the afr table 1 at the same time.
I read your instructions..... from above... I didn't realize that the default afr was a button..... yes I can change to the correct afr table... THANKS.
