MLV and status 1 to 8 graphic display?
Feature request - Can the contents of the status registers be presented graphically in Megalogviewer?
Similar to Crank, ASE, warm up, run, .... at the bottom right of the console, it would add a lot of "ease of use" to the experience. I am currently trying to look at what is happening with Idle VE, Air Con, Fan and having to sit here with a calculator converting dec to bin to see what is happening with bit 5 or 6 is a lot harder that ideally it could be.
Thanks, Arran
Thanks, Arran
http://web.aanet.com.au/arran
Re: MLV and status 1 to 8 graphic display?
It is on the todo. Right now all you can do is create a calculated field that will display if the bit is on and off. That helps a great deal, but isn't what a stand alone indicator would be.
Thanks, ill keep an eye out for any updates. Also thanks for the tip on the calculated field.
Arran
Arran
any updates on this?
Based on what I read in the embedded help in MLV I put together this formula to display when idle ve is active:
[Status6]>15&&[Status6]<32||[Status6]>47&&[Status6]<64||[Status6]>79&&[Status6]<96||[Status6]>111&&[Status6]<128||[Status6]>144&&[Status6]<160||[Status6]>175&&[Status6]<192||[Status6]>207&&[Status6]<224||[Status6]>239&&[Status6]<=255
I can't see how to use a BITTEST function like I'm more familiar with in Assembler, but with a combination of AND and OR the status6 value can be tested to see if it is BETWEEN a number of values, indicating that bit 5 is active. Not very elegant
A single ampersand, like in C.
value & mask
e.g. [Status6] & 32
value & mask
e.g. [Status6] & 32
Thanks, a couple of handy custom fields I've just setup:
To display when Closed loop idle is active:
[Status2]&128
To display when Idle VE is active:
[Status6]&16
To display when Idle Advance is active
[Status6]&32
The '&&' results in a true/false 1 or 0 result but did NOT correctly track the Status bit. '&' results in a decimal value and correctly tracks the bit value
[Status2]&128
[Status6]&16
[Status6]&32
The && is a logical AND, so both sides of it need to be true (non-zero), then the output will be 1.0.The '&&' results in a true/false 1 or 0 result but did NOT correctly track the Status bit. '&' results in a decimal value and correctly tracks the bit value
Where a single & is a bitwise AND, so the output will be the value after applying the mask.
Example:
64 && 32 = 1
32 && 32 = 1
(32+64) && 32 = 1
64 & 32 = 0
32 & 32 = 32
(32+64) & 32 = 32
You can use binary to make it look clearer:
0b00100000 & 0b00100000 = 32 (0b00100000)
The output is always in decimal, but the input can be Hex, Oct, decimal or binary.
Sorry for the hijack, but can I use bit wise & to mask the upper 4 bits of a value?
I want to log wheel speeds via CANbus, but they are first 12 bits and I need to throw away the 4 highest order bits.
Sent from my XT1080 using Tapatalk
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Yes.
Mask it with 0x0fff
Not sure how MLV accepts the C-style 0x prefix for hex ??
That's 4095 in decimal.
i.e. [raw value] & 4095
Mask it with 0x0fff
Thanks!jsmcortina wrote:Yes.
Mask it with 0x0fff
Peter Florance
PF Tuning
PF Tuning
MLV's Math parser is fine with the 0x prefix or 0b for binary 0b111111111111
Very cool. ThanksLT401Vette wrote:MLV's Math parser is fine with the 0x prefix or 0b for binary 0b111111111111
Peter Florance
PF Tuning
PF Tuning
