AFRvolt field
AFRvolt field
does anyone know where the O2 or AFR volt field has gone with the new updates in MLV?
or has it been called something else?
I have looked in all the fields multiple times but cant find it.
I ran an old log file and it was there as "o2" as an option , but in my latest log , its not there.
thanks
thanks
AC COBRA ,302H.O, 33lb inj, 70mm throttle,TFI ign, AFR 165 heads, X303 cam, MS2Extra 3.3.3
Re: AFRvolt field
MLV only displays what is in the datalog. So if a field is missing - you need to look at the program that created the datalog - TunerStudio.
Most likely you have changed your "Project Properties" to ask for AFR instead of O2 volts or changed from narrowband to wideband.
Re: AFRvolt field
Ok thanks.
So does that mean I should display AFR volts on the dash board for mlv to pick it up?
I did change to wideband, how would that change the ability to display volts in mlv?
Re: AFRvolt field
The firmware "ini" file uses your Project Properties-> Settings to determine what TunerStudio records into the log file.
Code: Select all
#if NARROW_BAND_EGO
entry = egoV, "O2", float, "%.3f"
entry = egoV2, "O2-2", float, "%.3f"
#elif LAMBDA
entry = lambda1, "Lambda", float, "%.3f"
entry = lambda2, "Lambda2", float, "%.3f"
#else
entry = afr1, "AFR", float, "%.2f"
entry = afr2, "AFR2", float, "%.2f"
#endif
Re: AFRvolt field
Sorry James but the last post is above my pay scale. Are you saying that because I now have wideband selected it won't display volts no matter what.jsmcortina wrote:
OR are you saying I need to create some ini file code to create it?
OR is it just a case of selecting the o2volts gauge to display in the dash?
jsmcortina wrote:The firmware "ini" file uses your Project Properties-> Settings to determine what TunerStudio records into the log file.JamesCode: Select all
#if NARROW_BAND_EGO entry = egoV, "O2", float, "%.3f" entry = egoV2, "O2-2", float, "%.3f" #elif LAMBDA entry = lambda1, "Lambda", float, "%.3f" entry = lambda2, "Lambda2", float, "%.3f" #else entry = afr1, "AFR", float, "%.2f" entry = afr2, "AFR2", float, "%.2f" #endif
Re: AFRvolt field
What James was getting at is much simpler...
In TunerStudio open "Project Properties" by selecting:
File --> Project --> Project Properties
or
press CTRL+P
On the settings Tab, check what is set to "Oxygen Sensor / Display" or "EGO Sensor Selection" depending on your firmware.
or
press CTRL+P
Re: AFRvolt field
Thanks. It's set up as oxy sensor/display and wideband selected.
So what does that mean for displaying O2 volts in MLV?
Should it appear?
Should it appear?
Re: AFRvolt field
Yes.ollykiwi3 wrote:Sorry James but the last post is above my pay scale. Are you saying that because I now have wideband selected it won't display volts no matter what.jsmcortina wrote:
Re: AFRvolt field
ok.thanks.
is there a reason why the o2 volts was dropped when going from narrowband to wideband?
was it something people just werent using or not a function that was required to be seen. i would have thought it would be more useful with wideband than it would be for narrowband, but what do i know.
