TQ and HP doesn’t work anymore
My TQ and HP logging used to work fairly well. A couple of months ago it just stopped working. Hp + TQ show min -9.22 max 9.22
See record 126, it jumps from TQ 227.5 to 9.22 to NaN
Also have a very rough AFR 1 Target graph see record 455
Quite a few updates since last year. So what happened or must I change some settings to make it work again??
1992 Corvette C4, modified 397ci engine using MS3X, CNP, 36-1 t-wheel
Re: TQ and HP doesn’t work anymore
What is that log from?
Are you using the HP & TQ fields from MLV or the Power and Torque getting logged from TunerStudio?
The TS Logged Power and Torque seem to match your description.
Check the settings in TunerStudio under:
Data Logging --> Power and Economy Fields
I'm logging from TS see picture. It's the only way I ever do it, always worked before.
Everything looks sane there..
When did it seem to break?
There should have been no changes to that for sometime...
What firmware are you running?
I will need to try reproducing that, perhaps it is related to being in metric?
Phil, I tried looking up and found the following:
04.25.2014
pretty much ok. 584 HP 553 TQ
11.14.2014
min: -1008 Hp max: 1699 HP way too much
11.17.2014
min: -9.22 HP + TQ max: 9.22 HP + TQ
Firmware: MS3 1.3.2
04.25.2014
11.14.2014
11.17.2014
Firmware: MS3 1.3.2
Phil, I'm still hoping you will find out why my HP & TQ isn't working anymore.
arnold1
Phil is currently out of town till the end next week, I will let him know that you are still looking for a solution to get the TQ and HP calculations working.
Phil, thought I bring up my thread again since nothing has changed.
I even changed vehicle weight and units to lbs, still not working properly.
Strange it worked fairly well until summer 2014 and I think because of an update things got screwed up.
