I noticed this a while back and forgot to mention it. It is likely an issue not commonly stumbled upon as most likely don't have a need to use them.
When you are looking at the recommended tables in VE Analyze, none of the table modification tools are working. I have an odd mountain that keeps getting built, and went to knock down the offending cells. Nothing I would do in that table would "take" and change those. As soon as I accept new table, I can then go an make the changes I want in the main section.
I base the readiness of a tune on max cell change. But in a case like mine above where I am getting sometimes stupid cell changes (sometimes it will add 16 or more to my "mountain") I would like to see where that max cell change is. And in fact most of the time, I want to know where that cell change occurred so I know what portion of the map it is, and if I need to be concerned when tuning boost etc.
Would it be possible to highlight the bin with the max cell change?
Table Tools broken, and tool request
Forget the porn, my bathroom is full of car manuals...
1977 Rabbit (retired)
1991 Cabriolet (retired)
Re: Table Tools broken, and tool request
This is in reference to MLV?
Yes. I still rough in my tuning offline using megalogviewer. I am referring to the ve analize table before you hit "accept new table". If it isn't clear what I am referring to let me know and I will try and explain better.
