After the auto update to v4.0.18 yesterday I noticed that the blue tail tell thing usually bouncing around in the tuning tables only shows up very randomly, frozen or not at all when running the logs. Same problem on both my computers, W8 laptop and W7 stationary.
Uninstalled the v4.0.18 and reinstalled v4.0.15 and everything worked fine again. Tried the update once more but same problem back.
Have tried different settings without result.
Any advice welcome
Regards JanM
Problems after update
Re: Problems after update
I noticed the same issue after the update.JanM wrote:After the auto update to v4.0.18 yesterday I noticed that the blue tail tell thing usually bouncing around in the tuning tables only shows up very randomly, frozen or not at all when running the logs. Same problem on both my computers, W8 laptop and W7 stationary.
Any advice welcome
Regards JanM
Bug?
I was tuning on the dyno today and noticed the same thing....
Should have a fix out tomorrow.
4.0.19 is up with this fixed.
Thanks Phil!
Thank you! now it's ok
