Trip feet logged field
I have the trip feet checked in the log fields and it reloads the file, but the option is not present in the menu. Ive used this feature before for timing out 1/8th and 1/4 mile times Im on 4.0.19
Re: Trip feet logged field
The formula in the .properties file seems to be referencing MPH instead of the proper canonical, so if you add a Calculated field to alias that to VSS1, it should work.
Create a Custom Field:
Name:
MPH
Formula:
[VSS1]
Name:
MPH
Formula:
[VSS1]
Thanks Phil. I meant to update this as a while back we discussed this, I found the old thread where you had me name a custom field.......... Distance and gave the formula using vss2 as reference. Works perfect Comparing time slips to a datalog the data is so close I can use it to tune at the new track that doesn't have a timing equipment yet
