joining log files
Carlos
joining log files
Post by Carlos »
I did a few long runs, logging data with my Galaxy Tab and shadowtuner, which works perfectly well btw. No more bulky Laptops :yeah!:
Now I have two log files in size 58MB and 18MB.
What I'd like to is to somehow join these files before running VEanalyze.
Is there any simple way to do so?
Alternatively I thought about having the analysis made with the smaller log first, then taking a screen shot of the results and finally dropping the analysis.
Then I want to run the Analysis with the large file, and manually compare and change values, based on the screen shot I took first.
I need to apply both files as the first one was mainly cruising, second one was upper/top range in RPM and load.
too confusing ? :)
any help apprecciated
regards
Carlos
Update: I wanted to do a test drive, even with only one of the logs being used for tuning. So I opened my current project, in there tried to open the modified tune. -- Signature doesn't match.
I did not use the tablet for logging before, what did I do wrong and how can I fix that signature issue?
Megasquirt MS-III, FW 1.3.0 20140305, JBperf I/O Extender FW 0.1.2, connected via Bluetooth to TunerStudio 2.6.14
MSD 6AL, MSD distributor, TWM induction - individual runners 48mm, Chevy V8 SB, Bosch injectors, crank triggered 60-2, Innovate LC-1
Re: joining log files
Post by LT401Vette »
In MLV you can load multiple log files by holding the CTRL button down while selecting files in the File Open dialog.
The signature mis-match means the modified tune was made with a different ini file than you are loading to.
Do you know what firmware you are using?
Carlos
Post by Carlos »
Wow, that simple ? Thanks !
The FW is FW 1.3.0 20140305
Did the joining as you described, worked well, no signature mismatch.
Not sure what I had messed up, but now it worked.
