Hi all..
DIYPNP firmware 3.4.1
When attempting to run VE analyze through Megalog viewer, every time I click the Analyze VE button I get a message saying,
"The following fields are required for VE analyze to work effectively:
Map
EGO
AFR
MAP
The following parameter should also be logged for better results:
Water"
So, when I first installed Megalogviewer I was able to run VE analyze without issue. I haven't changed any log parameters in TS. I've double checked that the above parameters are selected to log in TS and all are besides "Water" because I don't see it on the list. Since I've been using Shadowdash to log,being able to use VE analyze is important. Any help is greatly appreciated. Thanks!
VE Analyze not working
Re: VE Analyze not working
Water?
My 1st guess would be that Field Naming has been changed from Auto Detect under:
Options --> Field Naming (Log ECU)
However, I don't know of any field mappings off hand that have a field called Water.
Can you post an msq a short msl that creates that error?
