Changing the third and fourth graph colors
Postby vw_chuck » Sun Oct 01, 2017 5:35 am
I selected to display 4 graphs(16 parameters) on screen but it only allows me to change the color for the first 8 parameters color? How do I change the other 8 parameters colors?
vw_chuck
Re: Changing the third and fourth graph colors
Postby LT401Vette » Sun Oct 01, 2017 3:07 pm
If you have 4 graphs with 4 selectors per graph.
On the Main Menu, select:
Options --> Graph Trace Color
The colors are listed per trace, Graph 1 should be 1-4, Graph 2 should be 5-8, Graph 3 should be 9-12, etc.
As you update the 1st 2, I think you know this so I assume this is not happening this way?
I just tried it and it seems Ok?
Postby Marek » Mon Oct 02, 2017 12:01 am
Is this a case where the menu disappears under the bottom of the screen because it is a laptop and it has a small screen, so you can't see the remaining menu options?
kind regards
Marek
Marek
Return to Megalogviewer
