Custom Field - Math Parser Functions
W126
Post by W126 »
the following custom field works in TunerStudio custom.ini:
EgoDelay = { tableLookup(array.ego_delay_table, array.ego_delay_rpms, array.ego_delay_loads, rpm, afrload1) }
I've tried to do the same in Megalogviewer:
EGODelay
tableLookup([array.ego_delay_table], [array.ego_delay_rpms], [array.ego_delay_loads], [RPM], [AFR load])
What's the correct syntax ?
Does tableLookup work in Megalogviewer ? How does Megalogviewer know the tune ?
Re: Custom Field - Math Parser Functions
Post by LT401Vette »
In MLV there is no ini file loaded to do the table lookups on.
We are looking at putting in some way to do lookups on some sets of tables as it would be useful in several scenarios.
W126
Post by W126 »
Thank you Phil, I'm looking forward to that feature.
