blue tooth and usb cable at the same time
i have been having commutation problems between TS and my ms3x. will having both the blue tooth and the USB cable connected at the same time cause a drop in commutations. the usb is on the USB 2.0 Hi-Speed A to B Device Cable and the blue tooth is on the rs232 9 pin serial port.
Re: blue tooth and usb cable at the same time
Ive had both plugged in and not noticed any issue but never tried using both at the same time.
Is it possible to blue tooth to a tablet dash and have a laptop in a passengers lap?
this may have been asked before but this is first thread i found as a newbie to the forum and thought id ask
That won't work. One at a time only. The other must be unplugged.
Even just plugged in at the same time can cause random drop out issues.
I don't have them plug in at the same time. I have the usb and the blue tooth plugged in the ms all the time because its tucked under the dash. I plug in the usb or link up this the Bluetooth on the lap top side. Is that ok?.
While talking over USB with a Bluetooth Adapter plugged in (not doing anything). This has worked fine for me at times, then other times I start getting drop outs over USB, unplug the BT Adapter, and it is good.
Ok that clears thing up.
