I have to say TS rocks and Phil, you make tuning an enjoyable pastime !! I sent $20 for MLV that's a deal and then some !
I just got into TS and I am getting an error when trying to access output port settings.
I get the following warning, "std_port_edit not found in current configuration. Perhaps it hasn't been created.'
Also my only other gripe is that you cannot import tables (VE, Ign, AFR, etc), but with that said I have never seen an MSQ flash so fast !!!!!
Error when attempting to access 'Output Port Settings'
Re: Error when attempting to access 'Output Port Settings'
Yep, that dialog is about the only one still missing. It is only used on MSII base code. I have to get it done soon.I get the following warning, "std_port_edit not found in current configuration. Perhaps it hasn't been created.'
Yeah, I keep getting reminded of this, it should be in the next releaseAlso my only other gripe is that you cannot import tables (VE, Ign, AFR, etc)
Ah, that is because TS cheats. It only send the delta, the bytes that do not match what is already on the controller...but with that said I have never seen an MSQ flash so fast !!!!!
So if you load an MSQ where the only thing that changed was a few table values, well those are all that is sent to the controller. That make is fast I've a had a few emails where people thought it didn't work because it was so quick. I had them go back and take a second look and tada the changes were there
