TS Speedometer?
TS Speedometer?
I noticed in the project properties there are fields entering stuff such as vehicle weight, and your gear ratios. What I didn't see was a "predefined gauge" to make use of these fields. It would be pretty cool to have instant miles per hour, a speedometer, etc. Are those fields there to be taken advantage of later, or am I missing something?
L28ET I-6 Motor | MSII Extra v3.0 PCB | EDIS Coilpacks & Module | Boost Control | Knock-Sense
Re: TS Speedometer?
Yes, those are there to be used later. Now the speedometer still has the problem of needing a VSS signal. That opens the doors for a lot of others.
