I decided to try the Lag Compensation again. I could not get it to burn with 987.4
When I would open up the menu again, just plain EAE was selected. The lag compensation menu line stays grayed out.
I did test it in Megatune and it seems to work ok.
MS2Extra210 01/29/2009 version
Phil, you're a victim of your own success. TS works so well with my laptop, I'll try to use it as often as possible. OT, I don't know what else I changed, but the lag compensation seems to work pretty well.
Thanks Phil
987.4 won't burn EAE with Lag Compensation
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Re: 987.4 won't burn EAE with Lag Compensation
I'll have to check it out.
Peter,
In the "Accel Enrich settings", if you set "Enhanced Accel Enrichment" to On, all the EAE menus will be enabled except "EAE lag compensation settings". For the "EAE lag compensation settings" to activate, you need to set "Enhanced Accel Enrichment" to "On with lag compensation" in the "Accel Enrich settings" dialog.
Does this fix it for you?
I'll try it again, but what I tried to do is select "On with lag compensation" from the drop-down and click 'burn'. When I closed the box, the Lag settings menu line was still grayed-out. When I went back to the Accel Enrich settings box, it was set to "On", instead of "On with lag compensation"LT401Vette wrote:Peter,
I don't know if I've ever used this in TunerStudio, and it's possible I had some mouse issue. I was able to get it to burn in Megatune right away but I know there a lot of differences.
I'll try it again when I get some lunch and do some screenshots.
Peter Florance
PF Tuning
PF Tuning
You shouldn't even need to Burn or close the dialog. As soon as you put it to that, it "Should" be enabled. I tried it here and it seems ok? Give it another try, let me know if it still isn't working.
