988.1 'Clear' Menus
988.1 'Clear' Menus
See attached.
Re: 988.1 'Clear' Menus
It must be throwing some type of exception so it never finishes the paint.
it looks like you were opening an msq without a project, can you post the msq that was doing it? And perhaps your TunerStudioLogFile.txt just after seeing this?
Is this repeatable? Is it only for this msq?
Unfortunately it's repeatable, here's a screen shot of a working project, trying to open an msq (not connected).
If I open a tune and go to reopen another one, it still does it. Happens over multiple projects as well.
Looked at the log file, there's all sorts of java errors, but I know this worked before.
The log file is too big to attach. I'll copy clip it below:
5/11/09 10:36:12 AM :Debug: removing COnfiguration: Neal Bob
5/11/09 10:36:12 AM :Debug: Opening project: C:\Documents and Settings\pkiernan\My Documents\TunerStudioProjects\95 GTI VR6 - Stock Injectors - Gas - HR
5/11/09 10:36:13 AM :Debug: MS/Extra format hr_10 **********
5/11/09 10:36:13 AM :Info: (Unimportant) Missing page for:
BarroCor, "&Barometric Correction", { baroCorr1 }
5/11/09 10:36:13 AM :Debug: Loaded Config in : 265ms.
5/11/09 10:36:13 AM :Info: Error going online, perhaps we are not attached to a controller.
5/11/09 10:36:13 AM :Debug: Adding Configuration: 95 GTI VR6 - Stock Injectors - Gas - HR
5/11/09 10:36:13 AM :Debug: !!! Loaded config in 343
5/11/09 10:36:13 AM :Debug: Working Config:com.efiAnalytics.a.T@ce0bb
5/11/09 10:36:13 AM :Debug: !!! Activated Project 390
5/11/09 10:36:14 AM :Debug: !!! Opened Dash 1125
Exception occurred during event dispatching:
java.lang.NullPointerException
at com.sun.java.swing.plaf.windows.WindowsComboBoxUI$XPComboBoxButton.getState(Unknown Source)
at com.sun.java.swing.plaf.windows.XPStyle$GlyphButton.paintComponent(Unknown Source)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintChildren(Unknown Source)
at javax.swing.JLayeredPane.paint(Unknown Source)
at javax.swing.JComponent.paintToOffscreen(Unknown Source)
at javax.swing.BufferStrategyPaintManager.paint(Unknown Source)
at javax.swing.RepaintManager.paint(Unknown Source)
at java.awt.GraphicsCallback$PaintCallback.run(Unknown Source)
at sun.awt.SunGraphicsCallback.runOneComponent(Unknown Source)
at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
at java.awt.Container.paint(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.seqPaintDirtyRegions(Unknown Source)
at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Unknown Source)
at javax.swing.JFileChooser.showDialog(Unknown Source)
at javax.swing.JFileChooser.showOpenDialog(Unknown Source)
at com.efiAnalytics.util.DialogUtil.a(DialogUtil.java:156)
at com.efiAnalytics.util.DialogUtil.b(DialogUtil.java:87)
at com.efiAnalytics.tunerStudio.W.c(AppEventManager.java:356)
at com.efiAnalytics.tunerStudio.b$P.actionPerformed(MainMenuManager.java:364)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
That was from the last project load on, there's a lot above it. I'm going to reinstall JRE and try it again.
I see how to reproduce it....
It seems to only happen under the "Windows Classic" Look & Feel.
I'll see if I can figure out why, in the mean time, switch to another Look & feel under the Menu:
Options --> "Look & Feel"
Fixed, thanks!
Noticed two other things, I can't connect to the update server for updates and when I try and manually update I get this error:
Never have seen that before.
Are you on Vista? Have you recently installed any type of Protection software, i.e. Firewall or Virus protection.
That looks like some other app is not allowing connectivity or administrative access.
XP Pro SP2.. strange though it worked before.
