If i export ny AFR Table only to save it then i try to import it i get following error
original AFR 14.7 after import i get 14.0 this happens with all numbers.
Behind the dot it write after the import a 0.
TS version 0.988.7
ciao Frank
Export import AFR
Export import AFR
Ciao Frank
RS2000 16V msextra GSlender 2.8 (better than OEM)
Re: Export import AFR
Yes, that looks likem a problem. I'll look into it...
I should enable the table format, I hate the VEX format, it is pretty sloppy and very limited.
But it should work for that
Yeah, this is happening with the spark table as well. It was really throwing me for a loop - I was trying to build and export a table and I'd re-import it and all the zeros were dropped off. It drops off the decimal for both the values and the table indexes...
btw, the version I'm running is v0.988.7a
