toyota vast ing.
toyota vast ing.
looking for toyota Vast ing. settings Also is there a way to transfer MSQ file from Megatune to this? is this ok to use with MS1sns?
Re: toyota vast ing.
The toyota ign options should be in the same place they would be in MegaTune.
The msq's are compatible, you can load one that is saved from MegaTune, or you can just connect to the controller and save an new one.
And yes all MegaSquirt current firmwares are supported, MS1 Base Code, MS1 MSnS-Extra, MS2 Base code, MS2 Extra, MS3.
