system requirements
system requirements
TunerStudio v0.989.7 hangs when I try to open a project. Actually, the whole machine stops responding to the mouse and keyboard and the disk light is continually lit. This is on a 500MHz Pentium III with 160MB RAM running Windows 98SE and JRE 1.5u20. Should this work?
Steamer
MSIIv3 on a 2332 VW
T25 Intercooled Turbo
JAW WBO2, fuel and spark control
MSIIv3 on a 2332 VW
Re: system requirements
It should work, probably not well but it should work. I know several people running on 500 MHz or less machines, but the win98 part really hurts. Win98 run multi-threaded apps and java terribly slow compared to the same hardware with a real OS. But I wouldn't expect the result you Are seeing.
