Hi Phil, that took care of it you are the man.
Thanks, David
Error Mesage
Re: Error Mesage
Re: Error Mesage
This is the only thread i found while searching error message "Content is not allowed in prolog". So i decided to post my question here to keep the subject centered.
I an fiddling around with tunerstudio (Running the MS2-Extra-Example file, No MS connected).
I generated and loaded an ignition and afr table as instructed in the megamanual without issues.
I also tried the VE table generator on megamanual to create an Initial VE table for my engine. But i get this error when trying to load it into my project.
Is used the following settings:
Idle RPM is 600 RPM
Est idle vac. Is 24 Hg
RPM redline is 12000 RPM
Peak flywheel hp is 100hp @ 12000 RPM
Peal torque is 50 lbft @ 10500 RPM
Engine displacement is 0.75 L
Engine max boost is 0 psi
Next save as VEX file via notepad.
When i load it in Tunerstudio i get the "Content is not allowed in prolog" why am i getting this error with the VE table?
Idle RPM is 600 RPM
Re: Error Mesage
Can you post the file you are trying to load?
