Tune Analyze Live setup
What is a good "EGO Control" setup for using the "Tune Analyze Live" function?
Re: Tune Analyze Live setup
Run EGO Control as you normally do.
Wideband sensors are less accurate as you move away from Stoich. So by having EGO Correction on, the MS has the opportunity to bring the fueling closer to correct providing VEAL with a more accurate AFR to calculate the proper setting.
It will work with EGO Correction off, but normally it is recommended to have EGO Correction turned on.
Thank you . . .
