I would like to make a second dashboard page especially designed for tuning AE.
My question is this: would it be possible to insert the two tunerstudio AE graphs (MAP AE and TP AE) as standard in the tunerstudio dashboard? Now I have to re-open them each time and position them again, which is not very convenient when driving. And these graphs are the most practical tool to see what is happening in the AE.
Rene
AE graphs in Tunerstudio dashboard
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Innovate LC1 wideband lambda sensor
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Re: AE graphs in Tunerstudio dashboard
Are you referring to the Curve Graph settings in the Acceleration Wizard dialog?
Yes, the two curve graphs with the moving line indicating the level of mapdot/tpdot. Essentially I would like to implement these as fixed in the dashboard.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Combining settings panels into dashboards is something slated to be done. But you can not currently.
Ok, Thanks.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
