strange TS errormessage
Since a few days TS gives an error message when I open my tune. I don`t know what caused it or how to fix it.
The error message says something about initial values PWM. Not sure what to make of it...
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Innovate LC1 wideband lambda sensor
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Re: strange TS errormessage
Of course...
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Hmm, I'm not getting it...
Maybe can you post / send a project archive?
File is too big. I will send you the file.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
I got your archive, but still not getting that error.
When do you get the error? When loading the msq? When opening the dialog?
I got it a number of times upon loading the tune. strange thing is that it doesn't always give the error.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Just to add, I was getting the same thing last weekend. I'm on MS3 1.3.1 and latest TS. It was showing up as soon as I was opening the "Closed loop idle settings" dialog and it was totally random (only doing sometime).
1993 Chevrolet Cavalier Z24
3400 Turbocharged Inter-cooled
MS3 v3.57+MS3X
MS3 v3.57+MS3X
Even more errors this morning. See the picture. The errors occurred on opening the closed loop idle dialog field.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
I think I came up with the path to reproduce this. The expression looks valid, so I believe it is a parsing error in TS.
Ok, thanks
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Ok, i'll give it a go later this week. Thanks.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
